loud exhaust but not too loud
loud exhaust but not too loud was created by sam47
Posted 11 years 9 months ago #102599
Afternoon fellow MGers
Clean bum
Advice please on buying a new exhaust. I would like to replace my existing exhaust for s/s and i like the look of the MGOC sports exhaust for £300. But not sure if it will be too loud.
Do they come with a volume control :slapme: or can I get my money back if i want to swop :nonod: I will get the local MG garage to fit.
I have got used to Clive passing my house at 6.30 am on his way to work. i also have very good neigbours which i would like to keep.
So am unsure what i want, but i do know I want better than I have at the moment. ( standard exhaust )
I am down in Bedworth next weekend to see my daughter and am planning to pop into Stoneleigh on the Sunday. So I can check out exhausts when I am there. Also does the exhaust come with a Cat.
Next project would be an induction kit, but that is for another topic.
by sam47
Replied by quick_spider on topic loud exhaust but not too loud
Posted 11 years 9 months ago #102603
I have the MGOC supersports exhaust on my 160 - it's not too loud or offensive. I doubt you can get your money back, so it's probably worth listening to some at Stoneleigh.
The following user(s) said Thank You: sam47
Replied by Leigh Ping on topic loud exhaust but not too loud
Posted 11 years 9 months ago #102604
Replied by sherwood0_8 on topic loud exhaust but not too loud
Posted 11 years 9 months ago #102605
I have a blue flame on my MGF VVC and it sounds fantastic it not over the top loud but when you put your foot down it sounds rich and sporty they have a few videos on you tube it also comes with really nice tail pipes and if you put a K&N in the mix it will sound even better its the one to go for if you dont want a over the top boy racer sound
Replied by jac114 on topic loud exhaust but not too loud
Posted 11 years 9 months ago #102608
exhausts dont cone with the CAT There are several exhaust available if you can track them down.. search on youtube for MGF Exhaust and there will be plenty to hear.. this is my longlife
and this is it with the induction while driving
This is the SP Gran tourismo i have just fitted on the freestyle.. sound quality not good as my phone was trying to cut the sound levels
managed to clean up the sound a bit
Last Edit:11 years 9 months ago by jac114
Last edit: 11 years 9 months ago by jac114.
Posted 11 years 9 months ago #102610
Posted 11 years 9 months ago #102611
Replied by Blow-in on topic loud exhaust but not too loud
Posted 11 years 9 months ago #102618
I've got the MGOC Supersport on a standard 1.8i F and I think it makes a great sound but it shouldn't wake the neighbours unless you floor the throttle (which you are not going to do on a cold engine I trust). What I have noticed was a bit of a drone - a sort of resonance - with the hard top fitted at 70 or so....I've solved this by selling the hard top!
I can't compare it with other systems because I live in a vacuum up here but I like it!
Richard
by Blow-in
Replied by sam47 on topic loud exhaust but not too loud
Posted 11 years 9 months ago #102619
Thanks for your quick replies and advice guys.I will ask loads of questions at Stoneleigh. MGOC sports is looking favourite.
Does that mean the exhaust will fit to the existing cat? :-?
by sam47
Replied by John and Sue on topic loud exhaust but not too loud
Posted 11 years 9 months ago #102621
Yes, so long as you get the correct exhaust for your model it will marry up to the cat. You'll need new bolts and extended nuts and a new gasket.
Replied by midlife martyr on topic loud exhaust but not too loud
Posted 11 years 9 months ago #102623
I think TTs are very quiet
Well till you turn the ignition on :P
Replied by bensewell on topic loud exhaust but not too loud
Posted 11 years 9 months ago #102630
I cut the cat nuts off today it took ages to crack the gasket between back box.n cat 1.5hrs. I have the xpower its loud but not massively loud just drove off.the car ramps without a back box that is loud
Time to create page: 0.695 seconds
