Quad light painting
Quad light painting was created by sherwood0_8
Posted 11 years 7 months ago #114697
Hello was just wondering if any on has had a set sprayed recently and how much it cost ? would it be a easy diy job to do from a spray can I have a set the right paint code but they are a bit tatty could do with a re spray thank you
Replied by jac114 on topic Quad light painting
Posted 11 years 7 months ago #114700
just did them today.. look at my thread Tahiti to charcoal,
all you need is wet and dry assorted paper, 1 aerosol of primer 1 of your car colour and 1 of topcoat, plus elbow grease
cost around £20
by jac114
The following user(s) said Thank You: sherwood0_8
Replied by sherwood0_8 on topic Quad light painting
Posted 11 years 7 months ago #114702
so you sand down old paint prime then sand the top coat of paint then clear top coat? they look good
Replied by bensewell on topic Quad light painting
Posted 11 years 7 months ago #114703
My materials came in a bit more:
primer £1.00 (pound shop)
paint £15 (metallic - had to get it made)
lacquer £7
Posted 11 years 7 months ago #114705
sherwood0_8 wrote: so you sand down old paint prime then sand the top coat of paint then clear top coat? they look good
take the shine of the clearcoat as you can see in my pic, its dull. then prime, use wet and dry paper with water to flatten primer using about 2000 grit til glassy smooth then paint in your colour again flatten down if you need to spray again, leave for at least 24hrs for paint to cure then clearcoat. im waiting until tomorrow night before i clearcoat mine
by jac114
Posted 11 years 7 months ago #114706
another tip. just do a light coat of primer first, if you have missed a bit of rubbing down or any grease on it and the primer will part and leave a crack.. if that happens (it did to me) just let it dry and wet flat it again in those areas then go over again with primer
by jac114
Posted 11 years 7 months ago #114710
thanks thats great one last question if anyone can help me halfords paint is no good I need BRG HAM whats the best place to get this from ? rimmer brothers have it with clear coat £23.02 will one can do it I already have some pound land primer :woohoo:
Posted 11 years 7 months ago #114713
Be careful there's about three shades of BRG. Mine was TF BRG2 HFF i think.
Posted 11 years 7 months ago #114716
Cheers Ben yes their were a few but mine is defo HAM I had a new wing on it and it was a perfect match also hard top etc ;)
Replied by bryan young on topic Quad light painting
Posted 11 years 7 months ago #114759
sherwood0_8 wrote: thanks thats great one last question if anyone can help me halfords paint is no good I need BRG HAM whats the best place to get this from ? rimmer brothers have it with clear coat £23.02 will one can do it I already have some pound land primer :woohoo:
Halfords BRG Paint does not match HAM, if you want a correct match get it made up. wipe the panel with thinners to remove any wax, then rub down, plastic primer, base coat and finally clear coat. do not rub down the base colour coat because you will get the wrong colour.
The following user(s) said Thank You: mogatrons, sherwood0_8
Posted 11 years 7 months ago #114846
Well got my paint sorted just need some wet and dry and do I need to use plastic primer or will pound land primer do
The paint should be a perfect match as its OE paint from rimmer brothers
Time to create page: 1.469 seconds
