Engine bay cooling mods... options/ideas
- Diesel Destroyer
Engine bay cooling mods... options/ideas was created by Diesel Destroyer
Posted 11 years 6 months ago #116592Not nearly enough air flow to allow for effective cooling.. So a few have looked at modding bits n bobs to aid in ari flow
Andy Watson has a rather nice rear :slapme: boot lid I mean.. with some custom air vents...
Ive opted for Koos air vents on the side... Making some DD scoops for under the car.. and some subtle mods to the boot lid vents..
The Koos vents smoothed in..
Some vents from another boot lid chopped into my boot lid
The underside will be modded to open the hole up as big as it can go without letting water into the boot..
So.. anyone else done anything else? Pics? Ideas? Comments? Thoughts? Haters? lol
Replied by Davem on topic Engine bay cooling mods... options/ideas
Posted 11 years 6 months ago #116594http://www.the-t-bar.com/en/forum/32-wanted/88391-engine-bay-fan?limitstart=0
Replied by cjj on topic Engine bay cooling mods... options/ideas
Posted 11 years 6 months ago #116595Please Log in or Create an account to join the conversation.
- Diesel Destroyer
- Diesel Destroyer
Replied by Diesel Destroyer on topic Engine bay cooling mods... options/ideas
Posted 11 years 6 months ago #116597cjj wrote: I was considering similar, with a high volume rad type fan mounted under the slats with a temp sensor. This would force hot air out of the top vents and draw cooler air in through the side vents and under the car. It might be possible to get a more efficient fan to replace the one on the side vent so that more air is drawn in there too. Let's face it, I doubt MG went out of the way to get the best fan they could.
Ive been looking at high CFM fans too.. I plan to fit a manual overide switch on my fan too...
http://www.cbsonline.co.uk/product/8%22_Electric_Cooling_Fan_FAN8
Posted 11 years 6 months ago #116598I would measure up so that you have two fans, one totally covering each side of the vents and use proper car fans, or even motorbike ones which might be lower profile.
- Diesel Destroyer
Posted 11 years 6 months ago #116601I hear what you are saying about car/bike fans at high level.. But running ITBs I might be limited for room.. so might have to fit fans into the boot lid..
- philljoynes
Replied by philljoynes on topic Re: Engine bay cooling mods... options/ideas
Posted 11 years 6 months ago #116607Not sure if this applies here as much, but thought I would thow it out there.
- Diesel Destroyer
Replied by Cobber on topic Engine bay cooling mods... options/ideas
Posted 11 years 6 months ago #116627The standard fan alone, blows a good deal of the air out under the car following the path of least resistance, after the engine is switched off, trapping stagnant hot air in the engine bay.
By blowing some of the air out from up high and creating a partial vacuum in the upper reaches of the engine bay, I'm encouraging the cool air drawn in by the standard fan to better displace the stagnant hot air from the top of the engine bay, rather than just spilling most of the cool air out the bottom of the engine bay.
Noise isn't an issue, you don't notice any sound from them over the standard fan. You do however notice a lot more heat coming out of the vent when hold your hand over it. (hardly a scientific precision method of measurement, I know!) They bolt to the engine cover grill and are removed with it, to gain access to the engine.
DD those fans in your link link here look pretty much like what I've used.
