New exhaust
- the singing bush
- the singing bush
touchstone wrote: Hi Scott
Can't see an exhaust gasket on your list, and you're going to need one.
I have enough tools etc at my house to fit if you fancy doing the job yourself, and saving money.
Just give me a shout.
Ian, thanks very much for the offer but if it costs me an hour's labour then I'd rather pay someone, however once fitted - it will need an outing
Richard
- the singing bush
Ian, is this what I need?
- Red Rooster
- touchstone
- Apprentice MGer
[/quote]
The answer is yes, though I would advise not using those nuts and bolts as they will rust up the same as the ones already on the car.
This will cause trouble if you have to remove the exhaust for any reason in the future
I use stainless steel bolts with long closed nuts (you have to see them to understand). It'll make it future proof.
It just so happens that I have some going spare that you can have.
Give me a shout.
- the singing bush
If your nuts are better/future proof then I'll happily take them off you for a beer token or two?
- the singing bush
There the best sort. I didn't come across that set
Typical I've already ordered the others but thankfully Ian has some of those nuts
