Internal Heater Pipes
Internal Heater Pipes was created by neilr
Posted 11 years 2 months ago #127370
I have been lucky to just be able to use my F daily for some time now. However I still have a minor water leak which appears to be from the internal heater pipes. I would like to know what involved in changing them. Thanks
Thank You
by neilr
Replied by Smutmeister on topic Internal Heater Pipes
Posted 11 years 2 months ago #127371
My heater pipes had sprung a leak too - and this is something that will become more common as the cheap crummy steel with wafer thin black paint corrodes. Get used to it folks!
Short of removing the rear subframe to feed the replacements through the bulkhead I 'Dremelled' off the rusted pipes and replaced the long sections with 19mm OD aluminium pipe. The rear hoses were fine but I replaced the front ones with 19mm ID rubber hose* (I'll double check the measurements)
I then cable tied these to the side of the tunnel.
So far, so good.
Only a dead fish swims with the tide.
Replied by bensewell on topic Internal Heater Pipes
Posted 11 years 2 months ago #127372
That sounds a right swear words moment! I'll be getting a plumber out for that if mine goes lol.
Time to create page: 0.477 seconds
