Leaks and more leaks.....
- a Guest
- Visitor
Thirdly and probably most difficult to solve is the leak from the corner areas of the roof. There is a trail of water either side when I attack it with a hosepipe. It seems to be coming in around the velcro areas but the velcro appears to be taught.
Here are a few pictures of the sodden carpets and soundproofing. Was a bit like the Titanic (after it sank) on the surface! :bang:
Passengers footwell most likely the heater intake, either remove and reseal or fit a TF snorkeling style.
The rear window could be break down of the material once you get wicking like this it could be replacement time. Dry it thoroughly and clean reproof but be prepared to swap out.
... Or just fit the hardtop and take the soft hood indoors for tlc
http://www.the-t-bar.com/en/forum/25-adamelphicks-guides/19041-tf-air-intake-on-an-f-how-to-upgrade
Regarding the hood leak - this may sound a daft question but was the rear window properly zipped in?
Richard
- a Guest
- Visitor
The zip is fulled closed and it appears to be seeping in down the corners on both sides where the velcro joins together. Seeing as I have no intention of having the rear plastic window open-is there anything that can be done to permanently seal these areas? For example silicone or tiger seal on the velcro parts?
Thanks for advice on air intake-snorkel shopping it is!
Regarding the leak from the drivers footwell-is this just leaking from the same area through the air intake?
Longbridge Loony wrote: Oh dear my shopping list is growing. Wifey will be pleased! :coat:
LL
Did you ever solve the leak through the zip area?
Robin
Robin
