faulty wipers
When going to work today both wipers stopped to work - during heavy rain of course.
Both arms can be moved easily, so are disconnected from the linkage apparently.
:rant:
Couldn't check it so far - but may it happen that both arms pop out at the same time or should I expect something worse?
Have to find an apple to find the way home tonight...
:rant:
by Raccoon
- Leigh Ping
Usually, just the drivers side pops off to my knowledge Bertl. Here's my 2 fixes for that specific problem. Maybe your bar's come off further down nearer the motor?
Wiper Motor & Linkage replacement. Courtesy of PQD44 'Paul' & Blow-in 'Richard'. Cheers gents. :broon:
Last Edit:10 years 11 months ago
by Leigh Ping
Last edit: 10 years 11 months ago by Leigh Ping.
The following user(s) said Thank You: Raccoon
Hi when mine went I also got a mike satur replacement also drill a hole 2mm in the bottom of the wiper motor as the motor comes of a citron and is fitted upside down so the drain hole is on the top
by helsbyman
could check - and temporarily repair - it this morning.
Both bars felt off the motor, the joint is totally worn.
Happened apparently not the first time, all joints have been drilled and 'repaired' with screws and wire in the past...
Could fix it with a flat headed screw through joint and motor arm, but it's definitely time for a replacement.
by Raccoon
helsbyman wrote: Mike Satur then?
probably the best option
by Raccoon
Yes
I beleave his linkage is rose jointed so no problems once fitted :broon:
by helsbyman
Time to create page: 1.857 seconds
