new battery ?
new battery ? was created by helsbyman
Posted 10 years 8 months ago #140761
Hi all
Well on my way to the gym this morning the srs light come on then the abs then the speedo and rev counter stoped working for about 5 mins then it all came bak on again battery terminals are clean and tight, alternator new 2 months ago so that leaves the battery which is 5yrs 3 months old
Replied by Raccoon on topic new battery ?
Posted 10 years 8 months ago #140767
Eurocarparts has 15% discount on batteries currently.
Maybe you find a good offer.
by Raccoon
Replied by adamelphick on topic new battery ?
Posted 10 years 8 months ago #140769
Bit odd though - batteries normally deteriorate over time then suddenly die...... if it charges and starts the car OK, doesn't lose charge overnight etc then it's unlikely to be the battery. Have you checked the battery feed wires etc to make sure there are no loose connections, and the earth straps are not corroded on the bodywork connection?
Replied by Badger on topic new battery ?
Posted 10 years 8 months ago #140786
For the voltage threshold to drop low enough for SRS/ABS warning lights to come on the alternator must not of been charging, even with a flat battery once the engine is running and the alternator is on station you will get 13 to 14 plus volts, check with the Torque App if you have it.
I had an intermittent charging fault which turned out to be a poor connection on the charging warning light bulb, this was at the capless bulb holder that goes into the instrument cluster and connects to the copper strips. Sometimes when you switched on the ignition the charging light bulb would not come on, when this happened the alternator would not come on station as the bulb forms part of the circuit to create the initial EMF in the alternator winding's. I had to bend out the 2 tabs on the bulb holder then it was fine.
Could be an intermittent fault on the regulator in the alternator caused by heat or water (they all fail prematurely with this)
Was the alternator new, S/X or second hand?
by Badger
Replied by cairnsys on topic new battery ?
Posted 10 years 8 months ago #140794
The symptoms you describe are exactly the same as those when my alternator failed. Tat was only two months old as well (reconditioned) and actually burnt out completely.
Could it be early signs of alternator failure or a circuit fault as Badger suggests above?
Robin
Replied by talkingcars on topic new battery ?
Posted 10 years 8 months ago #140826
My first thought was alternator followed by a poor earth.
Time to create page: 0.706 seconds
