LED indicator lights blinking too fast
- Fatbaldingoldgit
LED indicator lights blinking too fast was created by Fatbaldingoldgit
Posted 10 years 9 months ago #141328
One of the issues with fitting rear lights with smoked lenses is that the dim-ish incandescent bulbs find it even more of a challenge to shine through effectively...Fitting higher powered LED bulbs is one way to address this but one of the problems is that this results in the indicators blinking too fast. You can get the same effect when one of the indicator bulbs has blown. Because the resistance of an LED bulb is lower than that of an incandescent bulb the indicator relay can't "see" that a bulb is present and so it blinks faster. It doesn't do this consciously, of course. It's just a factor of the design.
One of the fixes for this is to fit an LED compatible indicator relay. This how I overcame the problem when I fitted LED indicator bulbs to my Defender. Unfortunately, the flasher function on MG TFs with the Pektron remotes is performed by the SCU and it's not possible to change that.
Fortunately, it is possible to fix by adding extra resistance in the form of ballast resistors to the LED bulbs.
This is how I did it...
These are the LED bulbs I used..
2X 25W 7507/581/BAu15S CREE LED CANBUS BULBS AMBER INDICATOR LIGHTS FOR BMW
Here are the ballast resistors.
..and the connectors
