passenger door lock
Afternoon gentlemen
SWMBO has just told.me the passenger door won't open from the outside :rant: instead the handle just 'clunks'.
It does open from the inside though. Also the interior lights don't come on when the passenger door is opened so I'm guessing a new lock/mechanism may be in order
I've had a look at the 'dead locked ' how to. Good stuff there
by Simondi
- adamelphick
If the lock shut as normal and locks without the 'machine gun' sound then it is possible it is just the metal arm from the outside handle has come loose. They just clip on with plastic clips so best to check that first before buying a lock.
by adamelphick
The following user(s) said Thank You: Simondi
I'll have a look tomorrow after work, thanks for the responseadamelphick wrote: If the lock shut as normal and locks without the 'machine gun' sound then it is possible it is just the metal arm from the outside handle has come loose. They just clip on with plastic clips so best to check that first before buying a lock.
by Simondi
So I took the door card off and looked at the handle.
It seems as if the bar on the inside of the handle has worked loose so that the vertical linkage is not moving up and down thus meaning the door won't open from the inside.
When I get time I will remove the handle and have a proper look
by Simondi
Time to create page: 0.476 seconds
