LE500 Parking Aid wiring diagram needed
- Fatbaldingoldgit
LE500 Parking Aid wiring diagram needed was created by Fatbaldingoldgit
Posted 11 years 10 months ago #148738"You can’t be a real country unless you have a beer and an airline – it helps if you have some kind of football team, or some nuclear weapons but at the very least you need a beer"
- Frank Zappa
Replied by David Aiketgate on topic LE500 Parking Aid wiring diagram needed
Posted 11 years 10 months ago #148755
- Fatbaldingoldgit
Replied by Fatbaldingoldgit on topic LE500 Parking Aid wiring diagram needed
Posted 11 years 10 months ago #148757However the 2 wires to the buzzer up front are White and Red....so I suspect "something changes" in between..hence my query re a wiring diagram.
- Frank Zappa
Replied by Badger on topic LE500 Parking Aid wiring diagram needed
Posted 11 years 10 months ago #148814There will be a microchip in the system somewhere and the original buzzer may not be compatible anyway (different impedance/resistance etc.)
I think you will end up fitting the complete aftermarket kit and fitting the new buzzer under the dash.
Brian.
- Fatbaldingoldgit
Posted 11 years 10 months ago #148820No luck on a wiring diagram yet..I've emailed MG Motors UK...maybe I'll get a response after the bank holiday..and if so I'll post it...
I take your point re the difference between the original buzzer and the aftermarket one but I'd still like to know how the "spare" original wires connect to the original buzzer...it's not obvious even after playing with my multimeter..
- Frank Zappa
- Fatbaldingoldgit
Posted 11 years 10 months ago #149052Attached is the wiring diagram..not in great definition though..
I still can't reconcile it with reality..e.g no mention of white/red cable and the buzzer is supposed to be connected using Green/Brown cable..not what I see..However...
- Frank Zappa
Posted 11 years 10 months ago #149062Where is the buzzer mounted? it's shown as "PDC Sounder Unit Lamp Interior" is it mounted inside the rear view mirror?
Up to MY05 on the TF's the previous connector number used on the list in the electrical library is C0355, this is under the plastic trim on the windscreen surround by the interior mirror!
Brian.
- Fatbaldingoldgit
Posted 11 years 10 months ago #149064"You can’t be a real country unless you have a beer and an airline – it helps if you have some kind of football team, or some nuclear weapons but at the very least you need a beer"
- Frank Zappa
Posted 11 years 10 months ago #149079white with a yellow tracer
black with a grey tracer
Brian.
- Fatbaldingoldgit
Posted 11 years 10 months ago #149117"You can’t be a real country unless you have a beer and an airline – it helps if you have some kind of football team, or some nuclear weapons but at the very least you need a beer"
- Frank Zappa
- Fatbaldingoldgit
Posted 11 years 10 months ago #149148Also attached a couple of piccies showing the inside of the rear view mirror..for completeness..Also shows how the LEDs are located..
I'll create a How To (replace the OEM reversing sensor system with generic) eventually. First though I want to see if the existing buzzer in the mirror can be used.
- Frank Zappa
Posted 11 years 10 months ago #149155Job done.
Brian.
