Shorter Gear stick ????
Shorter Gear stick ???? was created by sherwood0_8
Posted 10 years 2 months ago #150641
Hello I was wondering can I swop out my F's gear stick with a shorter TF one is it a easy job just unbolt and pop off the ball and socket linkage on the bottom ??? then re attach ??
I have been looking at the slick shift but it seems expensive I have always thought the F's gear stick to be a bit on the long side :P
Replied by Sithmaull on topic Shorter Gear stick ????
Posted 10 years 2 months ago #150642
Saw half of the thread off with a hacksaw and reattach gear knob. Cheap as chips :)
The following user(s) said Thank You: sherwood0_8
Replied by bryan young on topic Shorter Gear stick ????
Posted 10 years 2 months ago #150644
People normally cut it off (Half of the thread) :clap:
Replied by PQD44 on topic Shorter Gear stick ????
Posted 10 years 2 months ago #150645
Here is an old How To from the comprehensive set of How To threads which can be found by clicking on the orange tab on the left.
Click here for the - Curing a sloppy gear change + Shorty Gear lever - How To
:nonod: Can't believe that was nearly three and a half years ago.
Replied by Andy Lawrence on topic Shorter Gear stick ????
Posted 10 years 2 months ago #150657
I cut all the threaded bit off and bought a knob that was secured by 3 grub screws.
WHALE OIL BEEF HOOKED
Replied by Plezier on topic Shorter Gear stick ????
Posted 10 years 2 months ago #150676
It seems that the MK 1 MGF gear lever is longer slightly than the Mk2 (MY2000) one. On the Mk 1 I ran a die nut down to the should extending the thread the used a MGB/Midget wooden knob which is much shorter:-
[IMG
The new knob and all of £7 .................
[IMG
No length removed from the lever itself.
Now on "Elsie" who's gear change was awful due to wear I fitted the whole unit from the MY2000 VVC donor and threaded that down the the shoulder then cut 3/4" off the length:-
[IMG
and that is the result. I have no idea why they needed such long gear knobs it's a gear change not a railway points lever.
by Plezier
Time to create page: 0.530 seconds
