160 injectors
I was just reading on ORG that the injectors on the 160 are working flat out to make the 160 bhp and that an injector rate of 250cc/min is a better option as the std ones work at 200cc/min. The person has used FORD ones on his TF at a rate of 315cc/min
by helsbyman
Only really of advantage if you have carried out mods that require more fuel.
I have
head mod, 4-2-1 manifold, chipped.
by helsbyman
Would probably require remapping to make best use of those new injectors.
So were do you go to get up rated injectors? I have seen injectors as BLUE, GREEN etc so I presume I want a colour that's different to mine, which ever colour that is?
Last Edit:10 years 2 months ago
by helsbyman
Last edit: 10 years 2 months ago by helsbyman.
Best way is to find out what car uses the injectors that you want and go from there.
Here is some info on injectors http://forums.mg-rover.org/showthread.php?t=260181s
Didn't want to post the org post but it is difficult to post the info over onto here without copying other peoples input.
The following user(s) said Thank You: helsbyman
Time to create page: 0.487 seconds
