Lolarm II
Trying to delay the well know HGF thought I would fit low level coolant when came across this Lolarm II has any one tried this as it is slightly cheaper than the better known Browns and Gammons (Price: 110.00 + 22.00 VAT = £132.00 (KIT) but I also know that sometimes cheaper CAN be false economy Please give any ideas/experience
Thanks
Thanks
by Branchman
Hi, after several months of digesting guys posts on this subject i also decided on the LoLarm II , sounds easier to fit, as no undercover working area hoping to fit sometime this weekend, everyone who's fitted them sound satisfied with the result.
by tjdonc
The following user(s) said Thank You: Branchman
I've had mine fitted for over a year & it' a good piece of kit. :yesnod:
Andy Capy, who makes & supplies them is most helpful if you have problems.
I found the position of the float to sensor critical & had to adjust set up for best results.
Check every so often, by depressing the float, that the system is operational.
Mine just let me know that the expansion tank was empty, due to a leaking rad.
by Forrester
We've had ours fitted for several years, it alerted us to leaking radiator several years ago and then a split hose on the way to POL last year
Have recommended it to dozens of F/TF owners and even fitted a few for those not physically capable
Test procedure? Simply drive the drivers side over a speed hump
Fantastic value for £67.50 delivered!
Last Edit:10 years 1 month ago
by mgfmania
Last edit: 10 years 1 month ago by mgfmania.
- bryan young
I decided to fit the B&G alarm to my F, good piece of kit, easy to fit and well worth the money. heard of many problems with LO-Larm, the sensors come unstuck from the bottom of the coolant bottle, Roger Parker MGOC put cable ties around the system he was testing for Andy Capy as the sensor kept falling off.
by bryan young
Time to create page: 0.490 seconds
