ipad2
ipad2 was created by idrawcad
Posted 9 years 11 months ago #154197
Do any of the tech people on here know how to bypass the appleID activation screen.
I have acquired a used ipad2 (perfectly above board) but do not have access to the previous owners appleID rendering the device useless.
Can anyone help.
Many Thanks.
Regards
Chris
  • Away
Replied by Cobber on topic ipad2
Posted 9 years 11 months ago #154198
I think that you need to reload the operating system then set it up with your Apple ID.
However my Apple experience is limited to Macbooks and iphones not ipads, so hopefully someone here can give you an answer based on actual experience.
Replied by cairnsys on topic ipad2
Posted 9 years 11 months ago #154201
If you've got access to the Internet, try googling Apple Support, then click on iPad. There's something there about erasing a locked ipad.
I've not done this so do t know if it will work or not but it's along the lines of
This will erase the device and its passcode.
Disconnect all cables from your device.
Hold down the Sleep/Wake button, then "slide to power off" to turn off your device.
Press and hold the Home button and plug the device into your computer. If your device doesn't turn on automatically, turn it on. Don't release the Home button.
Continue holding the Home button until you see the Connect to iTunes screen.
If iTunes doesn't open automatically, open it. iTunes will alert you that it has detected a device in recovery mode.
Click OK. Then restore the device.
If your device doesn't go into recovery mode, try steps 1–4 again.
I don't suppose you'll be able to connect to iTunes unless you have another account but at least it might clear the device.
Last Edit:9 years 11 months ago by cairnsys
Last edit: 9 years 11 months ago by cairnsys.
Replied by Raccoon on topic ipad2
Posted 9 years 11 months ago #154210
Sorry Chris, only two ways to activate it in this case:
- you get the Apple ID & password from the previous owner
- if you get the original sales receipt AppleCare can unlock it
If you do not get one of these it's only a nice decoration on your desk... :spank:
The previous owner had 'find my iPad' and an activation lock set up, even after a full restore the device will ask for the login details.
Last Edit:9 years 11 months ago by Raccoon
Last edit: 9 years 11 months ago by Raccoon.
Replied by idrawcad on topic ipad2
Posted 9 years 11 months ago #154223
Problem now sorted thanks
Regards
Chris
  • psymon
  • 2001 MGF 1.8 in MNX
Replied by psymon on topic ipad2
Posted 9 years 11 months ago #154225
Bertl wrote: Sorry Chris, only two ways to activate it in this case:
I've had success in the past with, Use a I tunes which has never seen that device before, Plug Ipad in whilst turned off , Turn on and hold the home button until I tunes finds the device. Should then have the option of a Full Factory restore from within i tunes , which removes find my device and any apple accounts
Last Edit:9 years 11 months ago by psymon
Last edit: 9 years 11 months ago by psymon.
Posted 9 years 11 months ago #154249
idrawcad wrote: Problem now sorted thanks
For future reference, what was the solution?
Time to create page: 0.493 seconds
