Mg advert and pro mo vids
Mg advert and pro mo vids was created by mgtfbluestreak
Posted 8 years 8 months ago #165730
A lot of you have seen these before,but some newcomers may enjoy them.....here are some..mg adverts :drive:
Last Edit:8 years 8 months ago by mgtfbluestreak
Last edit: 8 years 8 months ago by mgtfbluestreak.
The following user(s) said Thank You: Leigh Ping, Andy Lawrence, mgtftone
Replied by Andy Lawrence on topic MG ADVERTISING
Posted 8 years 8 months ago #165732
That can't be real Shirley.
Looks like a poor sixth form project!!
WHALE OIL BEEF HOOKED
Replied by mgtfbluestreak on topic MG ADVERTISING
Posted 8 years 8 months ago #165734
thats why the tf had faded badges?
Replied by mgtftone on topic Mg advert and pro mo vids
Posted 8 years 8 months ago #165742
Just watched the videos. Very interesting one on the development of the k series engine. Did they say cambelt life was 96,000 miles? To use a quote from Andy "whale oil beef hooked". :yesnod: .. Must have been before they invented HGF. ;)
The following user(s) said Thank You: Andy Lawrence, mgtfbluestreak
Replied by mgtfbluestreak on topic Mg advert and pro mo vids
Posted 8 years 8 months ago #165743
mgtftone wrote: Just watched the videos. Very interesting one on the development of the k series engine. Did they say cambelt life was 96,000 miles? To use a quote from Andy "whale oil beef hooked". :yesnod: .. Must have been before they invented HGF. ;)
yes i found the k series engine project interesting.......brought back some memories of working in a factory in the early 90s when we recieved hundreds of thousands of k series castings to undergo a special casting sealing process......like to see another video of those 2 guys crying and trying to explain how many engines had hgf....
The following user(s) said Thank You: mgtftone
Posted 8 years 8 months ago #165745
I can remember ally castings being anodised to seal the surfaces, was that the same process? I can also remember mechanics with dirty hands ;) not like in the video. :nonod:
Posted 8 years 8 months ago #165747
mgtftone wrote: I can remember ally castings being anodised to seal the surfaces, was that the same process? I can also remember mechanics with dirty hands ;) not like in the video. :nonod:
We had truck loads of k series blocks,cylinder heads bearing racks etc.......these were deliverd 24 hours a day from rover
The process was called metal impregnating.........as alloy castings had microscopic holes in them.....porous ...they have to be sealed.......this was done by carefully loading the castings into a large cylindrical basket which was hoisted into a vaccum chamber..........once loaded in the chanber door was auto closed and with a flick of a lever all air sucked out....after a set time.a button was pressed that pumped a special resin into the chamber of castings.........once the correct amount of resin was in the chamber another button pressed which put the castings under preasure.......assuring resin was in those pores.......timing was strictly observed and after the resin pumped back out....the steel basket was hoisted out by the overhead crane.....i think the basket could handle well over a ton has we also did large cylinder heads which wieghd around 3/4 of a ton each for merlees in manchester........after the casting were hoisted out the were washed several times automatically being submerged in and out of cold water and then put in a tank of hot water to cure the resin......while one basket of castings was coming out of the vaccuum tank another was awaiting to go in.......lorries arrived night and day to bring and takeaway those luvly new k-series parts........not knowing that one day i would get to own one......and for anyone thinking was itpossible to send some castings back without treatment.....then the answer is no....rover scanned these castings under ultraviolet light to check the process was completed.....oh and about mechanics having dirty hands im now in the engine recon buisness and overalls come back from laundry service looking like they have been washed in 15w-40... :hgf:
Posted 8 years 8 months ago #165748
Thanks for the insight of what happened with the castings. I was in engineering for 25 years, find it intetesting as to the different processes used. :broon:
Posted 8 years 8 months ago #165749
mgtftone wrote: Thanks for the insight of what happened with the castings. I was in engineering for 25 years, find it intetesting as to the different processes used. :broon:
i wish id taken photos of the plant .......i actually work next door to it but the building is empty and the plant long gone.anodising also done in the plant.....mainly small castings like air control items........oh whats this? ive just found a video explaing the process the k series engine parts went through at our plant.
Posted 8 years 8 months ago #165751
this last vid now in this post a tribute to mg rover
The following user(s) said Thank You: sworkscooper, mgtftone
Time to create page: 0.583 seconds
