How low can you go ?
Having given my mg a bit of a pump up I thought I would ask the question,
how low can you go ?
spotted this on the bay
seems pretty low
seems pretty low
by jaypay
- adamelphick
Unless you have lowering knuckles fitted you should have it at 368mm from the wheel centre to arch edge (+/- 10mm) measured at 17 degrees C. The sphere pressure shoudl be around 400psi (+/- 10psi ish).
Last Edit:7 years 8 months ago
by adamelphick
Last edit: 7 years 8 months ago by adamelphick.
How low?
Not that low, the car will just crash over every bump and get stuck on speed humps.
by talkingcars
Just passed its MOT according to the listing so the tester must have thought it was ok ! Like you said it must be a nightmare to drive . they must not have got speed bumps like the ones near me.
MGF 1.8 VVC - LOW MILEAGE - 1999 Registered - 12 mths MOT
by jaypay
