Clutch pedal will not press down at all
- glennrover
- Novice MGer
Clutch pedal will not press down at all was created by glennrover
Posted 5 years 11 months ago #193805
Any ideas /usual fault for this? Thanks.
by glennrover
Replied by Raccoon on topic Clutch pedal will not press down at all
Posted 5 years 11 months ago #193806
Did you check the basic thing first - is there something stuck behind the clutch pedal?
Second option could be a faulty clutch master cylinder.
by Raccoon
- glennrover
- Novice MGer
Replied by glennrover on topic Clutch pedal will not press down at all
Posted 5 years 11 months ago #193809
It has been left standing a while!
by glennrover
- SundanceUK
Replied by SundanceUK on topic Clutch pedal will not press down at all
Posted 5 years 11 months ago #193823
More than likely a seized clutch arm, they have a tendency to seize up where the shaft goes through the housing especially if they have been standing a while. Can be freed up but they are a bit awkward to do, Mine was getting a bit stiff, but I had it sorted when the clutch was replaced a couple of years ago. It was removed, cleaned and re greased.
Try some penetrating oil and see if you can work it loose, you may need someone to operate the clutch while you try to lubricate the arm.
You can access it from the top if you remove the engine access panel. Don't use WD40 as its not a true penetrating oil. Plus gas or Rocal or similar make is best.
Sundance
Sundance
Last Edit:5 years 11 months ago
by SundanceUK
Last edit: 5 years 11 months ago by SundanceUK.
Replied by talkingcars on topic Clutch pedal will not press down at all
Posted 5 years 11 months ago #193868
Do not keep pressing the pedal in the hope that it will clear, the chances are that you will blow the slave cylinder.
by talkingcars
Last edit: 5 years 11 months ago by talkingcars. Reason: speeling
Replied by g7nbp on topic Clutch pedal will not press down at all
Posted 5 years 11 months ago #193912
Agree with all of the above.
Disconnect the slave cylinder pin, then trickle plusgas into the housing around the shaft and use a length of tube slid over the arm to get a little more leverage to gently wiggle the arm free.
Ideally the bell housing would come off and the shaft come out to remove any pitting and to regrease it, but this is non-trivial in the F/TF and you may get away with working it loose and then trickling a medium density oil in.
A better long term solution is to replace the clutch arm with one like the Mike Satur ones with a grease nipple built in.
by g7nbp
Time to create page: 0.375 seconds
