Screen Wash
  • eagle
Screen Wash was created by eagle
Posted 16 years 8 months ago #1113
I suspect that most of you would agree that the screen wash pump on the MGF/TF is not very effective. I have seen all sorts of tips on how to improve the output slightly, but none that seem to go to the basic problem. Just recently I came across a Land rover system that had two pumps for the front screen, one for each front nozzle. Before I try to manufacture something similar I thought I would ask my fellow conspirators if they could think of any problems I might encounter.
I wish
THe Lone Gunman
by eagle
  • gos
  • X Black Beauty X
Replied by gos on topic Screen Wash
Posted 16 years 8 months ago #1117
Eagle;1113 wrote: I suspect that most of you would agree that the screen wash pump on the MGF/TF is not very effective. I have seen all sorts of tips on how to improve the output slightly, but none that seem to go to the basic problem. Just recently I came across a Land rover system that had two pumps for the front screen, one for each front nozzle. Before I try to manufacture something similar I thought I would ask my fellow conspirators if they could think of any problems I might encounter.
I dont have a problem, before you go to all that trouble tho, have you considered the citroen jets mod for about a fiver I think, it has a sort of misting action and rather than a jet you get a fan spread across your windscreen.
couple of pics from inside and out;
[ATTACH][ATTACH]8[/ATTACH][/ATTACH]
by gos
Replied by jonnocash on topic Screen Wash
Posted 16 years 8 months ago #1121
my jets were to powerful they sprayed over the windscreen which was a bit annoying with the hood down. i used a pin to alter the direction of the drivers one which hits the windscreen fine (i left the passenger one cos its was funny:whistle:, but the jokes worn thin now:dunno:}
going to get the citreon ones when i get time to get to the scrappy and ill do the heated washer mod thats on here at the same time
Replied by mgfmad on topic Screen Wash
Posted 16 years 8 months ago #1125
As Gos says, the Citroen jets are a great mod - worth doing.
When I got my MGF the pump had packed up so I fitted one from a Range Rover - saw it on Ebay and the connection was the same so maybe mine are more powerful than usual.
MG TF LE500 27 of 500
by mgfmad
Replied by cjj on topic Screen Wash
Posted 16 years 8 months ago #1183
Get the citroen jets.
If you are lacking pressure it might be a blockage or loose pipe.
  • eagle
Replied by eagle on topic Screen Wash
Posted 16 years 8 months ago #1228
Gos;1117 wrote: I dont have a problem, before you go to all that trouble tho, have you considered the citroen jets mod for about a fiver I think, it has a sort of misting action and rather than a jet you get a fan spread across your windscreen.
Yep, have fitted those, but not the improvement I am lookin for.
I wish
THe Lone Gunman
by eagle
  • eagle
Posted 16 years 8 months ago #1229
CJJ;1183 wrote: Get the citroen jets.
Cleaned out the entire system, fitted new pipes, another pump, Citroen jets even tried removing the return valve, but still only get a little water to the bottom of the screen.
I wish
THe Lone Gunman
by eagle
  • eagle
Posted 16 years 8 months ago #1231
MGFmad;1125 wrote: As Gos says, the Citroen jets are a great mod - worth doing.
Now that could be an Idea, a Land Rover pump.
I wish
THe Lone Gunman
by eagle
Time to create page: 0.477 seconds
