tracking help please
tracking help please was created by g4wam
Posted 14 years 8 months ago #11384
hello all--can someone help with a question about MGF tracking ..
I need to set the front of my MGF to 5 degrees toe -in but my local centre can only deal in millimteres -what is the conversion please?
I have 15" wheels by the way
Mike
by g4wam
Replied by adamelphick on topic tracking help please
Posted 14 years 8 months ago #11386
g4wam;11384 wrote: hello all--can someone help with a question about MGF tracking ..
Mike
If they don't have laser alignment equipment then don't get it done! The F and TF need to be properly 4 wheel laser aligned.
Also the toe in depends on your bush set up as well.. if you have standard it's different from say what I have with standard + nylon compliance washers. Here is a page that will help:
http://www.apttony.co.uk/Servicing/Compliance.html
Replied by g4wam on topic tracking help please
Posted 14 years 8 months ago #11390
thanks for your advice.
Here is some more detail to the question.
I am going to fit a poly bush kit from MGF Centre -there recommendation was then to trackmy MGF with 4 dgrees toe in front and parallel back -this being what they would do if i took it to them in Wolverhampton.
The only place local to me that has 4 wheel tracking capability will do the job if i can convert from degrees to metric -its odd i know
Mike
by g4wam
Posted 14 years 8 months ago #11396
hmmmm... all the 4 wheel alignment places round here use degrees as far as I know. Is it definitely laser alignment they will use?
Replied by quicksilver on topic tracking help please
Posted 14 years 8 months ago #11415
Mike
You would need to know the precise radius of your wheel and tyre, and a set of log tables to work that out. Sounds like your local garage have got an old style micrometer alignment rig. Dont touch it with a barge pole.
Posted 14 years 8 months ago #11427
thanks everyone -I decided to take the advise that -they know not what they do!!!
My best bet in the Midlands is to seek out the professionals at MGF Centre Woverhampton .
Did anyone see a post recently about replacing the normal clear MGF repeaters with Ford Focus style fancy repeaters ?
I bought some but cannot fit them without butchering my wiring
Regards
Mike
by g4wam
Time to create page: 0.511 seconds
