Coolant Reservoir FINALLY
- a Guest
- Visitor
This is the reason for replacement by the way...
:dc:
- adamelphick
Soon I should be launching a new replacement header tank and warning system for the coolant. Completely new tank and cap and all associated wiring. Hoping to keep the cost down as much as possible or at least similar to the MGR solution.
- a Guest
- Visitor
AdamElphick;11494 wrote: Blimey - that's BAD!!!!!!!!
I know! I couldn't believe it. My dad started pouring water in and told me to 'look for a leak', I just said almost right away, 'dad i think i've found the problem!' That replacement sounds good to me!
Gos;11502 wrote: Glad you got it sorted Tomm, best of luck with it:yesnod:
Thanks Gos, dad took it out to a social tonight and he said it drove fine so fingers crossed!
MGFmad;11504 wrote: No doubt that the old tank needed replaced!
It is rather bad, you should have seen the state the cap was in too, I held it all between my index finger and thumb, was disgusting!
- a Guest
- Visitor
