Any body handy with a tape measure
Just put the wings and lights back on my car to make sure it all lines up before welding it, And surprise surprise it doesn't line up, infact it seems to be about and inch out height wise. the new front stands about a inch higher than what its meeting up with.
The car is an MGF and the front part is a TF, i'm hopping its the Suspension mounts being difference which has thrown it out.
Could i get a couple of measurements from you guys, from a F and a TF, need the two marked A and B below.
Cheers
Cheers
by psymon
Here you go mate, I hope this helps. They are measured on a 1997 F VVC Australian Import.
Cheers
Craig
Cheers
Craig
by bacchus
Cheers Bacchus spot on (once i worked out your mesaure)
Anybody with a TF fancy giving me measurement A
by psymon
The TF has a different layout - you can see from the photo that the top shock mount is further back however I was able to compare this with my MGF and the hole you see in the photo is the mount position on the F. Its not so easy to get in with a tape because of the horn mounts - and take a photo but taking a stab at the position of the support bracket surrounding the mount (on the F) and measuring at the right hand side of this, up to the horizontal step, I get 65mm.
MG TF LE500 27 of 500
by mgfmad
Cheers Guys, That clears that up, Looks like the panel ontop the shock/Hydrogas is at a different height on the F than the TF.
Going to have to get creative with the welder.
by psymon
Psymon;11725 wrote: Cheers Guys, That clears that up, Looks like the panel ontop the shock/Hydrogas is at a different height on the F than the TF.
Double check before you fire up the welder - comparing my F & TF the 'A' height did look the same, but the horns did get in the way a bit:whistle:
by mgfmad
- a Guest
- Visitor
This one looks a better fit
ebay link
