Wheel refurb
also would I get good results if I do it from aerosol cans? Thanks
FM :rolleyes:
- gotenks1321
- Sand
- Fill with Chemical Metal
- Sand again
- Filler primer
- Sand
- Normal primer
- Sand
- Paint
- Sand lightly so the paint is dull
- Lacquer
FM :rolleyes:
- adamelphick
- adamelphick
gotenks1321;11935 wrote: Must admit that when I sprayed my interior I didn't bother to sand the top coat down before the lacquer and that still turned out ok :yesnod:
Interior is probably OK but on the exterior you need the extra adhesion to stop the top lacquer from peeling off the surface under hot and cold, and also due to stone chips. :yesnod:
FM :rolleyes:
- adamelphick
FrankM83;11942 wrote: thanks for your help, will not touch halfords paints for sure they're 2000miles away Thanks again
Haha only just noticed where you are! Lucky you for being so far from Halfrauds!
FM :rolleyes:
MG TF LE500 27 of 500
