Fitting a wind break
Yes this should be an easy job to do, just received my purchase of a wind break from ebay, all bolts and fittings, how do these things fit.....offered up the unit and the two wing nut ends supports have 1 bolt in each to be connected to the car but where? :confused:
i know this may need drilling but would like some advice on this:dunno:
kind regards
keith
kind regards
keith
by wilddog
Hi Keith!
There's a guide here: http://www.mgfcar.de/windstop ...not sure if that will be of some help to you?
Tbh I can't remember how I fit my windstop as I fitted roll hoops soon after so will probably end up giving you advice on how to fit hoops by mistake!! :yikes:
I think you had to take the plastic T-Bar off then there were a couple of holes in the metal t-bar underneath which you screwed the windstop in to.
Last Edit:12 years 6 months ago
by kara
Last edit: 12 years 6 months ago by talkingcars.
Time to create page: 0.500 seconds
