Mk 1 MGF windscreen washer operation
I recently purchased an 1996 MGF and have had it for about two months. I found this site after doing a web search so have been lurking for a while.
I have a query regarding the washer jets; if I pull the steering column wiper lever towards me, should the wipers cycle in addition to the washer jet operation? I would expect them to but mine don't. Has anybody any suggestions as to which components to check/replace?
dfv8;12271 wrote: Good afternoon all,
Hi and welcome to the T Bar
that is the way they are designed I'm afraid, some people like it like that (more control over wiping) some hate it, some even mod it so that it does but anyhow it isnt a fault.
btw rules are you must show some pics of your pride and joy
Thanks for the prompt response.
Interesting that it's supposed to be like that - very strange:confused:
Point taken re. the pictures, I'll post them up in the Welcome section later.
MG TF LE500 27 of 500
- a Guest
- Visitor
Replied by a Guest on topic Mk 1 MGF windscreen washer operation
Posted 14 years 7 months ago #12283Please Log in or Create an account to join the conversation.
Bosch;12283 wrote: It also has the advantage of letting check that the water jets have enough umph to wet the window first (common MGF issue)!!
Yeah, I'm already looking at the Citroen sprayjet conversion.
dfv8;12287 wrote: Yeah, I'm already looking at the Citroen sprayjet conversion.
good mod, see my pics;
from inside;
and out;
dfv8;12274 wrote: Interesting that it's supposed to be like that - very strange:confused:
Not really, that's how all cars used to be until all the driver aids were brought in.
The problem with auto wipe is that once you have pressed the button you are committed to 5 - 7 wipes. Normally this is OK, but if you have run out of squirter fluid the wipers will carry on regardless and smear the windscrean which is dangerous. Also the blades could be frozen in place or there could be ice on the winscreen, both will damage the blades.
I prefer to stick with the manual option.
Spray jets highly recommended. Reroute tubing under the bonnet so it doesn't use the L joint in the corner and you'll get better pressure and less freezing in the cold too
