Rev Limiter light
Ok, how and where should I fit a warning light to change up, say starting at 7000rpm.
Having broken a valve changing down a couple of weeks ago, I think I hit over 8000rpm ow, och. No damage just a broken and bent valve that did not even mark the top of the piston. Felt like a miss from a faulty plug, very lucky according to every one.
by andrewr
Do you mean something like a shift light? I know they come with auto gauge tachometer's but not sure if you can buy them on their own?
If you can then I would totally find a way to mount it to instrument cluster!
by kara
- a Guest
- User
I have a Raptor fitted. $200 from the USsolders onto the tach light wire at the passenger compartments footwell. Very easy, all programmable and works a dream.
http://www.raptorperformance.com/
Hi and welcome,
Which one/model do you have?
by andrewr
Never needed it, but I can see the advantage for track.
It wouldn't help on the downchange though.
Time to create page: 0.494 seconds
