Sump baffles
At the moment I am looking at the Minster Power, Lakeside engineering and Hellier performance units.
They vary in price from £350 +VAT for the Minster system, which is a CNC machined and Aly welded system (but you provide your own sump) to the Lakeside one for around £200, which seems to sit in the sump.
I am going to go for a baffled sump, just wondering if anyone can recommend any others.
I can't justify the expense of a dry sump system before anyone mentions it.
- quicksilver
You have mentioned all the best sources but it is fairly easy to make yur own. My race mechanic has said he will draw you a pattern for one if you fancy the diy method. Having said that , oil surge is not as big a problem in rear or mid mounted k series, as it seems mainly to afflict front engined set ups. Still worth doing for the supercharged unit because oil feed will be more critical.CJJ;12450 wrote: I am looking at sump baffling at the moment and wondered if any one knows of any good systems.
Chris
Had a good reply from Lakeside, so I think I will be going with them.
I realise that the baffling route for a mainly road going car is a bit overkill, but with the investment that I am making in this engine I don't want to risk oil starvation for the sake of £200.
While I am sure the Minster is a quality product I just think that £350 +VAT is a bit overkill, especially when you have to provide a clean and healthy sump yourself.
- quicksilver
Chris
