Wheel conundrum 03 TF
Was suprised when I lifted the bonnet to find no spare wheel,jack or wheel brace just a great big void and positioned at the bottom a polystyrene box with a pair of safety glasses and a tin or rusty crazy foam! (that didnt work.)
I presume Rover at that time were for cutting cost but hey,
So I decided to replace the void with a spare wheel.
Do I go for a space saver, another alloy ,a steel or what I thought.
Having looked into it, I came up with a confusing amount of nothing really.
A space saver is 14",
An Alloy is ok but what tyres size do I use,and what about a jack n tools.
Well I came across an old 200 series rover for the tools and a polystyrene box that is shaped to fit in the spare wheel inner, and as for the wheel I have a new alloy I found but still undecided as to what size tyre to put on it.
Does any one know why the space saver was an 14" wheel?
And whats the pros and cons regarding tyre sizes for spare wheels.
I assume the better option is to stick with a 185 as it will fit the front ok and will be a get me home for the rear,
Any advise appreciated
Thanks
Vex
FM :rolleyes:
If you are using the spare you should use it for the minimum time and keep below 50 mph.
FM :rolleyes:
shame the hole dia wasnt right.Must only be a few mills out but wouldnt fit as a spare.
I was wondering why the space saver wheel that was fitted to some TFs should be 14"?must be a bigger profile tyre maybe
Im now sorted with a new ally n tyre thanks
vex
- adamelphick
Might be a bit of kidology as to why but could def feel difference
