Poxy fob not working after battery change!
Poxy fob not working after battery change! was created by adamelphick
Posted 14 years 7 months ago #12519
Got a new fob repair kit - popped it on and now the poxy fob wont work!
I've tried unlocking the car with the key as the manual says - then pressing the lock button vigorously...nothing!
Likewise tried it locked and pressing unlock - nothing!
Also sometimes when I lock or unlock the car with the key the horn sounds once for a short 'beep'.
PLEASE HELP!!!!
Replied by adamelphick on topic Poxy fob not working after battery change!
Posted 14 years 7 months ago #12520
SOLVED - after trying THREE new batteries it suddenly started working!
Posted 14 years 7 months ago #12530
Well it is definitely ok again - so I bought a 'spare' on eBay...
Now the question is how do I get it programmed to Meg's ECU? Used to go to a dealer but is that still the case or is there a cheaper option?
  • Visitor
  • Visitor
Replied by a Guest on topic Poxy fob not working after battery change!
Posted 14 years 7 months ago #12533
AdamElphick;12530 wrote: Well it is definitely ok again - so I bought a 'spare' on eBay...
You could always try the 'ol method of - Removing the battery from fob, then walk away from the car, far enough out of the fobs normal working range, then press the buttons a few times to dissipate any residual voltage thats left in the fob, Pop the battery back in and go back to Meg. Lock and unlock with the key then press the lock button on the fob at least 5 times to re-synchronise........It won't work of course (does it ever?), but at least you've tried!!:yesnod:
Posted 14 years 7 months ago #12535
CheesyReich;12533 wrote: You could always try the 'ol method of - Removing the battery from fob, then walk away from the car, far enough out of the fobs normal working range, then press the buttons a few times to dissipate any residual voltage thats left in the fob, Pop the battery back in and go back to Meg. Lock and unlock with the key then press the lock button on the fob at least 5 times to re-synchronise........It won't work of course (does it ever?), but at least you've tried!!:yesnod:
It does work now - it's the SPARE one I bought that needs programming now - just in case the original goes doodah again! LOL
P.S. tried the method you suggested on the original during the battery fiasco - it would have worked if the batteries hadn't been dodgy!
Replied by bryan young on topic Poxy fob not working after battery change!
Posted 14 years 6 months ago #12612
Adam, Are you close to Russell Walsh MG Rover Solutions he will come to you with his MG Rover computer and programme it for you, takes about two minutes. He supplied a new programed fob for me for £45 , they cost about £40 to buy unprogrammed, he also gave me the EKA (emergency key access) code which i had previously paid £15 to get. if Russell does not do it, make sure you find out how much you will be charged for the programming! i heard of one case where the MGF owner was charged £180 for a programmed fob.
Hope this helps, regards
Bryan:
Replied by Adam-Mgtf on topic Poxy fob not working after battery change!
Posted 14 years 6 months ago #12671
dont talk to me about fobs, i popped the c/l motors in my TF 115, had a nightmare since, they did nothing so i got rovtec to enable them now the whole things haywire
the alarm sounds for no reason
the fob will stop working randomly
sometimes the alarm will arm but the doors wont lock or visa versa
and every now and again the solonoids will go haywire fiering whenever the door is open :(
Posted 14 years 6 months ago #12675
Brilliant - for some weird reason I never even thought of Russell!
Posted 14 years 6 months ago #12676
Adam-MGTF;12671 wrote: dont talk to me about fobs, i popped the c/l motors in my TF 115, had a nightmare since, they did nothing so i got rovtec to enable them now the whole things haywire
You sure you haven't got a short somewhere Adam?
Posted 14 years 6 months ago #12680
AdamElphick;12676 wrote: You sure you haven't got a short somewhere Adam?
no idea Adam, would need a garage to check for me and I don't want to spend that sort of mulah on anything but my V-Tech project atm
Time to create page: 0.609 seconds
