Coolant question
Coolant question was created by thatone1967
Posted 14 years 3 weeks ago #17502
Starting to loose a little coolant now, and need to top up. Brought some from Camberley Auto Factors, but it's a different colour.. (blue as opposed to the luminous green that I currently have) I am guessing you cannot mix them?
2003 MGTF Monogram Edition. Celestial Blue, Black Leather.No. 19 of 99 Built 11 Spoke Alloys. AP brakes.
Replied by adamelphick on topic Coolant question
Posted 14 years 3 weeks ago #17506
Blue/green is 'usually' the old style ethylene glycol - and pink/orange is 'usually' the new style OAT.... unfortunately this isn't always the case!
They don't mix very well at all and sometimes cause a gooey sludge. What year is the car and has it ever had a full coolant flush?
Replied by thatone1967 on topic Coolant question
Posted 14 years 3 weeks ago #17510
AdamElphick;17506 wrote: Blue/green is 'usually' the old style ethylene glycol - and pink/orange is 'usually' the new style OAT.... unfortunately this isn't always the case!
The car is an S plate, coolant never been flushed (by me anyway)
Posted 14 years 3 weeks ago #17512
Meg is an S and she had old ethylene glycol in when I bought her - I swapped all of it to OAT..
Replied by cjj on topic Re: Coolant question
Posted 14 years 3 weeks ago #17631
As said, colour is not the problem, it is what you have in at the moment. You shouldn't mix Glycol and OAT as it just makes a mix that won't have the correct properties and may result in problems further down the line.
If in doubt, drain the system and refil with whatever coolant you choose, but OAT is generally accepted to be the superior of the two.
Replied by bryan young on topic Re: Coolant question
Posted 14 years 3 weeks ago #17638
thatone1967 wrote: Starting to loose a little coolant now, and need to top up. Brought some from Camberley Auto Factors, but it's a different colour.. (blue as opposed to the luminous green that I currently have) I am guessing you cannot mix them?
Not advised to mix them, Ethylene Glycol and OAT that is, Bluecol now make a Clear colour antifreeze that can be used with either EG or OAT. as it has not been flushed before i would drain, flush and put in the latest pink/orange OAT (Organic Acid Technology) as it is far superior. it is also reccomended that you dilute it with de-ionised water and not tap water (because of the chemicals in it):)
Posted 14 years 3 weeks ago #17662
Totaly agree on the de-ionised water. You can buy iyt premixed though and the colour of OAT can be almost any colour you wish, you can even get blue, which is bound to confuse some people.
Time to create page: 0.495 seconds
