mgf service
1. spark plugs
2.ht leads
3.fuel filter
4. air filter (changed to a induction kit)
5.oil and filter
not sure what alse i might of forgot, what s.plugs and leads do you guys use or reconmend
Looking to the age and miles you should evaluate replacing the brake fluid, it would be a good opportunity to checks your pads wear.
Titanium wrote: HT leads the best choice MAGNECOR 8mm you can mail for pricing and pn to [email protected]
I have just replaced the clutch fluid as well. It was manky, black!
Won't need the power steering fluid, mate.:lol:rayb wrote: oh thats one i missed out clutch and power steering fluid
rayb wrote: its about time my 1998 mgf had a decent service one that i will carry out myself, i believe the last owner had neglected her, she runs fine tho.took her for a 80 mile motorway trip last week no probs, shes had a cambelt and coolant change im looking at changing
1. spark plugs
2.ht leads
3.fuel filter
4. air filter (changed to a induction kit)5.oil and filter
Ive been looking into doing this aswell. Looking around Ive seen kits from £30 to £200 so am a little confused as to which is best! Again lol.
Having said that I replaced our air box(mk2) with a Pipercross Viper cold air feed system. The car seems to breathe more easily and certainly sounds much better. Oh yeah!:woohoo:
I managed to get a second hand unit for £40 and a new feed pipe for about £15.
Look on ebay for induction systems from cars of about 1800cc, not just MGf/Tfs.
Mine came off a VW Golf, but the filter unit is identical.
I am approaching the end of my initial wants list and am now looking towards engine upgrades and have started a list for this.
I was looking at the K&N induction kit, which appears quite a bit cheaper than the Pipercross. What's the difference, apart from price pleae?
This reduces loss of cold air and more importantly prevents the hot air of the engine bay being sucked into the filter.
The K&N kits I have seen have an open cone filter with a cold air feed directed at it. The problem for our cars, having a generally much hotter engine bay, is that open cone system soaks up heat more than the enclosed systems.
You can get the K&N and make your own enclosure. I believe a Rover 800 series air box works well.
I've only just worked out what all the parts of the exhaust system do :ohmy:
david aiketgate wrote: Induction kits are a real benefit to Mk1 Fs which are strangled air wise. The Mk2s and Tfs are much better and a decent replacement panel filter would be good enough if you re-routed the air feeds to give cold air.
David, really great post amte. If it's not too much trouble could you put up a link showing exactly what you are talking about for us newbees please?
