coolant leak
Assuming you've got pink oat coolant, look for staining.
if you can, look from underneath with a torch.
I couldn't find a similar leak, but from underneath I could see staining under the inlet manifold.
And this is with the manifold removed.
- Rich in Vancouver
There was talk in the fall of alloy intake manifolds being produced.
I assume that this was one of the reasons for going that route?
Is there any more word on that project?
- rough luck
- Site Sponsor
- Jon
I used a temp fix but if I put it on open forum I would really take some stick for it, having said that it lasted another year till I had more money to through at it
Rich in Vancouver wrote: That photo is a great illustration.
I replaced the plastic one with an alloy one off a MGTF135, and it's been perfect since then.
it's a pretty easy job if you can source an alloy one.:yesnod:
Inlet Manifold gasket Replacement
- bryan young
rayb wrote: well the weather was good to day so jacked the car up and got the torch out carnt see any traces of coolant leak or stains from the inlet manifold area or block. theres no sign of any coolant stains anywhere its not even leaking now, so will have to investigate further. by the way my coolant is blue been in the car since i got it. i think my best chance is to get some coolant dye and a ultra voilet light .
Blue antifreeze is Ethylene Glycol, Pink is OAT (Organic Acid Technology) Have you looked for leaks around the heater pipes and the front radiator pipes and have you checked the underfloor pipes, these can weep around the welded brackets. the water pump shaft seal can leak too. are you absolutely sure that ther is no water in the oil?? check a cold engine to see if there are drops on the dip stick. how much do you need to top up each day :pinch:
