uprated head gasket
Replied by toby2fly on topic Re: uprated head gasket
Posted 13 years 7 months ago #22801
Rich,
The oil rail was very good price. In Ireland I think the garage charged about 200 euro for it incl fitting. They said it was'nt required with the Multilayer gasket and that it would add 200 to the overall cost of doing the HGF repair. I included it anyway as advised in the MG Enthusiast
Replied by bryan young on topic Re: uprated head gasket
Posted 13 years 7 months ago #22802
toby2fly wrote: David,
Thanks for the reply. Yes I have the low level coolant warning which worked and let me know about the head gasket failure. Did you replace the bottom oil rail with the upgraded one? it appears there is more thread for the bolts to thread into giving more stability to the head and prevent future failure
I would personally opt for the bottom rail, considering the small additional cost and after the problems that Kevin had with black sludge, i think it is worth removing the sump. Quicksilver has made a very valid point about not using one for normal unmodified use, but it does help to stiffen the block. There again, David didnt have it done on his and no further problems. :whistle:
Replied by cjj on topic Re: uprated head gasket
Posted 13 years 7 months ago #22849
The modified oil rail is part of the upgrade kit and the manufacturers of the genuine MLS kit will only warrant it if the new oil rail was fitted at the same time. It does stiffen the block, but apparently it also changes the harmonics and vibrations of the engine and lessens the movement between the block and head faces which occur naturally.
Time to create page: 0.490 seconds
