mgf ride height
could anybody tell me the ride height for the mgf, does it matter what size wheels are fitted to the car do you measure from the floor to the lip on the wheel arch or from the centre of the wheel to the wheel arch
by rayb
- Rich in Vancouver
You measure on the fronts from the center of the wheel cap straight up to the edge of the rubber trim on the wheel arch.
Stock is 368mm. Measure both sides as they aren't interconnected.
They are connected front to rear so no need to measure the rears.
Wheel size doesn't matter.
Last Edit:13 years 3 months ago
by Rich in Vancouver
Last edit: 13 years 3 months ago by Rich in Vancouver.
- bryan young
rayb wrote: could anybody tell me the ride height for the mgf, does it matter what size wheels are fitted to the car do you measure from the floor to the lip on the wheel arch or from the centre of the wheel to the wheel arch
YES, Rayb i can answer this ~ the dimension is 368mm plus or minus 10mm measured from the centre of the wheel to the centre of the wheel arch. it does not matter which size of wheel you have, because the have the same overall diameter, due to the lower tyre profile. The car should be left to stand for about an hour before taking the measurements to allow the suspension to settle. :thumbsup:
by bryan young
Time to create page: 0.482 seconds
