MGF Indicator fault Update
MGF Indicator fault Update was created by Tsleight
Posted 13 years 3 months ago #27504
Changed the Indicator unit - fault still apparent! Hazard lights come on with indicators. Flasher unit??? :-? Or the dreaded dodgy earth...
:nonod:
Replied by cjj on topic Re: MGF Indicator fault Update
Posted 13 years 3 months ago #27511
Most hazard switches connect all of the indicators together, so could be a good place to start.
Did it start by itself? Or after some work had been done?
Replied by Tsleight on topic Re: MGF Indicator fault Update
Posted 13 years 3 months ago #27512
Just by itself. Wife came home from work and said the indicators weren't working properly. When i checked, all indicators came on whether i clicked left or right. Still the same. Occasionally works correctly, but mostly all lights come on. The opposite dash light flashes more faintly than the normal side, but externally all the indicators flash as if hazards were selected. Hope that makes sense...
Posted 13 years 3 months ago #27521
Do you know anyone you can swap the hazard switch with just to rule that out?
Replied by talkingcars on topic Re: MGF Indicator fault Update
Posted 13 years 3 months ago #27544
When you say indicator unit do you mean the stalk?
Replied by Rich in Vancouver on topic Re: MGF Indicator fault Update
Posted 13 years 3 months ago #27546
I would put my money on the hazard switch. I was quite surprised when I took the F out for a test drive with the console out and found that everything flashed with the switch out. Could be that the plug is loose on the back of the switch. Pull the center dash vent out and you can easily reach the back of the switch and the plug.
Posted 13 years 3 months ago #27552
Yes, the stalk has been changed. I'll try hazard switch next, after checking its connector...
Posted 13 years 2 months ago #27960
Hazard switch, flasher unit and indicator stalk all replaced - fault still apparent. Argh! :rant: Looks like bulbs or wiring next... :(
  • Visitor
  • Visitor
Replied by a Guest on topic Re: MGF Indicator fault Update
Posted 13 years 2 months ago #27961
check for crushed wiring,boot connecters often fail,and the earth on front indicators often fail.and clean the earths up.enjoy
Posted 13 years 2 months ago #28164
Looks like a dodgy connection/wire at the plug into the fuse panel (9 / 10 way white plug near flasher unit). Wiggled wires/removed and reconnected plug. Faulty lights dimmed and brightened as the wires were moved until fault disappeared. Will monitor to see if it comes back...
Replied by David Aiketgate on topic Re: MGF Indicator fault Update
Posted 13 years 2 months ago #28167
It's good you've isolated the fault, :yesnod: but another one we can put down to the cheap/poor electrical kit that MGR used. :nonod:
I've just isolated an intermittently operating passenger window to the plug behind the switch. :yesnod:
Posted 13 years 2 months ago #28175
:rant:
Time to create page: 0.555 seconds
