tf oil clock led change :) how to :)
i purchased a TF clock and oil temp gauge for my f to do blue led back light
any way read the attached how to and made a discovery that you don't need to put any resistors on the clock or oil gauge as they already have them on (i just traced the circuit with a DMM)
if you use LED'S with 30mA max current then you will be fine
so here is the proof
the 475 ohm resistor on the pcb for the original LEDs (clock)
LEDs fitted 3mm 30mA 30deg angle 3000mlcd
LEDs working on 13.5v supply
here is the oil gauge resistor
here is the LEDs fitted (same as the clock) and polarity of the LEDs
so there you have it just solder the LEDs the correct way round so no more fiddly fitting the resistor
hope this helps
mark
hope this helps
mark
mad about cars and bikes
if it aint broke dont fix it
by MGF MARK
Replied by MGF MARK on topic Re: tf oil clock led change :) how to :)
Posted 12 years 10 months ago #37621
and if you want to add a red pointer here is the photos to help
if you have a close look you will see where to solder the led to and the reistor
i used a 1.2k
and here is the result
leds used
from Farnell (off the website)
blue 3mm 1716703 16p each
red 3mm 1716697 15p each
1k resistor 1700237 35p for 50
green lesd 3mm 1716704 20p each
just found this photo of my clocks in my old car and converted switches
i used a 1.2k
leds used
Last Edit:12 years 7 months ago
by MGF MARK
Last edit: 12 years 7 months ago by Leigh Ping.
Replied by psymon on topic Re: tf oil clock led change :) how to :)
Posted 12 years 10 months ago #37622
Nice, Thank goodness for decent size pads to solder on to. :broon:
by psymon
Replied by Bob on topic Re: tf oil clock led change :) how to :)
Posted 12 years 10 months ago #37657
Looks great way brighter than mine do.
I'm a chicken I just put new blue bulbs in.
by Bob
Posted 12 years 10 months ago #37666
been doing them for peeps for a couple of years also do some bits on the stra forum
by MGF MARK
- a Guest
- Visitor
Replied by a Guest on topic Re: tf oil clock led change :) how to :)
Posted 12 years 10 months ago #37667
Hmmmmmmmmmmm :evil:
You can do the How too on an F next week
Thank you for the marvelous champagne xxx
Time to create page: 0.551 seconds
