Head Lamp Condensation
- general lee
;)I have just arrived home from work and I have noticed that there is condensation inside the head lamps. Please can anyone advise what causes this and how I can cure it?
by general lee
Is it a TF? Can't remember.
Check that all the rubber covers are correctly in place on the back of the light unit.
To be honest, a lot of them do it.
- general lee
Yes it's aTF, I'll check those out thanks:goodpost::goodpost:
by general lee
- adamelphick
One of Meg's TF lights was full of water in the base - I tried to dry it a million times and in the end took it off, and indoors left the hair-dryer going in one light hole, while the air went out the other hole. It took about 1 hour to finally dry it all out.
by adamelphick
I have the same problem, but, with the rear lights...
Angel to Devil in 0.2 seconds...[SIGPIC][/SIGPIC]
David Aiketgate;17095 wrote: Oi, stop using foul language or I'll give you one!
by teri
- a Guest
- User
i have heard that a sheet of newspaper over the front of the headlamp with it switched on does the trick ?
Same problem with the headlights, but the rubber covers seem to be in place...I think is a common thing in many TF, well, I don't care about it...:winkgrin:
by marti
- adamelphick
Well after several days of rain the condensation is back in Megs passenger side headlight - I'm guessing a leak somewhere in the seals around the lens is the culprit.
by adamelphick
Time to create page: 0.443 seconds
