Holes in floor!
Anyone know if these should be here unsealed? can't really see anything below them so the don't appear to go outside. The water doesn't appear to be getting in from beneath the dash area as there is no sign of it running on the foam behind the pedal area and same the passenger side.
Foam is currently spinning in the washing machine, and I'm getting a very strange look from Carole!!!!
Oh whilst at this I noticed a piece of masking tape that had been left from previous bodywork, just a wing replacement I would guess.
Peter
Older but certainly not wiser!
- adamelphick
Swerving;5407 wrote: Ok so it's a dry day here... at last So I have folded back the carpet in both footwells and removed all the different pieces of sodden foam, to notice... a hole in the floor each side, close to the holes that appear to be plugged with grommets.
Peter
Do you mean that little hole in the raised section? If so that's just a hole in that piece that lets the heat and smoke out when they spot weld it together (And is also useful to squirt waxoil in too!).
If you water is not coming in the traditional air box way, then I'd suggest the cheater is leaking badly, or you are getting water in from the rear and that is sloshing from behind the seats to the front.
I would dry it all out, then spray WD40 liberally all over to dispel any moisture (including inside that hole!), then wipe it all off after half hour of sitting there... it will leave a thin film of itself on the surface to stop water penetration being as bad if it gets wet again.
I forgot... I did have the windscreen replaced but with a superficial check that appears to be fine.
The foam attached to each wheel arch is damp at the bottom, where it appears to have soaked up from the floor and around the steering column, where it goes through the bulkhead seems ok.
I did the plastic tubing mod to the cheater seals and no sign of water coming round the mirrors.
Just have to do more checking and eventually use the garden hose I guess.
- adamelphick
Swerving;5424 wrote: Thanks for the replies, it seems as Adam suggests, the holes are 'designed' in. Car is now in the garage drying out what I couldn't easily remove. Carpets behind the seats seem quite dry and as there seems to be a square cross member beneath the seats I can't see how water would slosh from back to front or vice versa. What is strange is both front footwells are as wet, so either both cheaters leak badly or there is another problem.
Windscreen replaced eh? Not 'Autoglass/AutoWindscreens' was it? I had one replaced on Meg and it leaked like a sieve along the top seam, which then ran down the side! I only noticed one day when I was sat in the pouring rain and heard it dripping! Also had one of their de-laminate in the sun with air bubbles forming in the silicone sandwich!
Yes it was Autoglass that replaced it in May/June, so worth checking that. I will have to sit in the car while Carole sprays the garden hose on it I think.
Foam is nicely dry now but I am sat at work so can't do anything today!
How was it resolved with Autoglass? did they admit responsibility and replace it?
Swerving;5485 wrote: I will have to sit in the car while Carole sprays the garden hose on it I think.
That'll get the neighbours wondering.
![;) ;)](/media/kunena/emoticons/11.png)
- adamelphick
Swerving;5485 wrote: Oh Thanks Adam!
Finally afre many complaints they replaced it at a different fitting garage - When they took the side plastic trims off inside the black sealant was all over the place and squeeged everywhere... right shoddy job it was!
