annoying harmonic in my exhaust system...
annoying harmonic in my exhaust system... was created by Adam-Mgtf
Posted 14 years 11 months ago #5474
pretty much what it says on the tin, i have a vibrating harmonic at around 3k rpm, had it with my old back box and its still there having replaced it... can't hear it when accelerating through 3k rpm but when slowing down its there and if just happen to be cruising at just the right rpm its irritating as... well its irritating
so anyway it's not the backbox it seems (which is odd because it wasn't there with my original exhaust (im on no3.) any ideas what it is and how to fix it?
Replied by kara on topic annoying harmonic in my exhaust system...
Posted 14 years 11 months ago #5478
Could be a hole in the Downpipe mesh.
by kara
  • gos
  • X Black Beauty X
Replied by gos on topic annoying harmonic in my exhaust system...
Posted 14 years 11 months ago #5484
my oem back box was fine but the TT does this at about 3000 revs and under acceleration load, has calmed down a bit after getting some miles under the belt, I did notice that it was very close to the bumper trim and was probably vibrating against it at speed, so cut some away with a hacksaw which did improve it.
also started to get used to it now too.
hope you get it sorted as it can be very irritating, good luck
by gos
Replied by cjj on topic annoying harmonic in my exhaust system...
Posted 14 years 11 months ago #5489
It could be the outer mesh loose on the flexi pipe.
Replied by reaper on topic annoying harmonic in my exhaust system...
Posted 14 years 11 months ago #5561
My old R25 longlife exhaust did this, i think its the k series engine. It is anoying!
[SIGPIC][/SIGPIC]
by reaper
Posted 14 years 11 months ago #5562
Reaper;5561 wrote: i think its the k series engine. It is anoying!
How very dare you.
Posted 14 years 11 months ago #5564
Adam. Get it up on stands and stick your head under while somebody revs it. Be careful though and make sure it is securely chocked etc.
I have to admit I was surprised how good your home made system sounded. Even had a turbo sound to it.
Replied by Adam-Mgtf on topic annoying harmonic in my exhaust system...
Posted 14 years 11 months ago #5659
CJJ;5564 wrote: Adam. Get it up on stands and stick your head under while somebody revs it. Be careful though and make sure it is securely chocked etc.
thanks mate :) and i think its pretty dam good, if you think the other systems there cost in the region of what £300? mine cost me £30 if you include the welding gas, wire and buying the exhaust its self :) i know the daytona and miltek sounded better but for a cash strapped laddie it works :) im hoping adding mikeknights de-cat will give it a bit of a throughty daytona barrrrp to it :)
i think the "turbo" noise is more from the air filter than the exhaust :)
Posted 14 years 11 months ago #5661
Gos;5484 wrote: my oem back box was fine but the TT does this at about 3000 revs and under acceleration load, has calmed down a bit after getting some miles under the belt, I did notice that it was very close to the bumper trim and was probably vibrating against it at speed, so cut some away with a hacksaw which did improve it.
thanks gos it might just need bedding it, its a 'used' backbox but now it's been rebuilt... kind of.
it could be vibrating against something like, when i put on my de-cat i think i'll try cjjs idea of running the car on stands
Posted 14 years 11 months ago #5666
Adam-MGTF;5659 wrote: if you think the other systems there cost in the region of what £300? mine cost me £30 if you include the welding gas, wire and buying the exhaust its self :) i know the daytona and miltek sounded better but for a cash strapped laddie it works :) im hoping adding mikeknights de-cat will give it a bit of a throughty daytona barrrrp to it :)
Ah yes, but you must remember that the Daytona etc aren't designed just for noise but give better breathing and an increase in power too.
Posted 14 years 11 months ago #5671
CJJ;5666 wrote: Ah yes, but you must remember that the Daytona etc aren't designed just for noise but give better breathing and an increase in power too.
ok make me feel bad :(
no wait...
come to think of it this is a call to arms i shall make a exhaust that humms "she'll be coming round the mountain" as the engine ticks cool
Posted 14 years 11 months ago #5678
OK, go on then. :)
Time to create page: 0.509 seconds
