Warning Light
Warning Light was created by simsimma
Posted 12 years 4 months ago #61398
hi all,
the amber light on my dash stays on when im driving.
What does this mean? and is it serious.
Its just come back from a MOT and hasnt been on before ..
Replied by John and Sue on topic Re: Warning Light
Posted 12 years 4 months ago #61399
What symbol is on the lamp?
Replied by simsimma on topic Re: Warning Light
Posted 12 years 4 months ago #61401
any ideas?
Last Edit:12 years 4 months ago by simsimma
Last edit: 12 years 4 months ago by Leigh Ping.
Replied by bensewell on topic Re: Warning Light
Posted 12 years 4 months ago #61404
Thats the engine management light. You need a code reader to check it out.
I got a cheap OBD2 one from ebay and cleared my fault with my phone.
Check these out:
http://www.the-t-bar.com/en/forum/9-mgf-tf-pitstop/52267-how-to-use-a-bluetooth-odb2-reader#52267
http://www.the-t-bar.com/en/forum/21-david-aiketgates-guides/3819-OBD2
A garage will charge you £40 for this to be done.
I'd recommend getting one :)
Posted 12 years 4 months ago #61405
Mines the pre-cat lambda thats gone on mine its constantly on but I can monitor it with my bluetooth thingy
Posted 12 years 4 months ago #61406
If it wasnt on before the garage had the car i would bat it back to them. Sounds like they have done something.
Posted 12 years 4 months ago #61407
where do you plug this into then? im not to clued up on this coding thing
Replied by Leigh Ping on topic Re: Warning Light
Posted 12 years 4 months ago #61408
For anyone with a My2000 on a car that is OBD2 compliant then this reader is a very cheap tool. :yesnod:
Ebay OBD2 Readers link.
They come with a booklet with a comprehensive list of codes.
It plugs into this port here within the fusebox compartment under the steering wheel.
Last Edit:12 years 4 months ago by Leigh Ping
Replied by talkingcars on topic Re: Warning Light
Posted 12 years 4 months ago #61413
As you haven't set your location so you appear to be in Ohio!
Where abouts are you?
I will happly plug my scanner in for you and read the code.
However it may disappear anyway. Sometimes if the ECU doesn't detect a fault over a number of ignition events it will clear the light, this happened yesterday on my wifes ZR after some brake work.
On our F the EPAS light come on after the emissions test on the MOT but clears once you drive properly.
Posted 12 years 4 months ago #61416
talkingcars wrote: On our F the EPAS light come on after the emissions test on the MOT but clears once you drive properly.
Ooh.. a pearl of wisdom right there. :broon:
The following user(s) said Thank You: simsimma
Posted 12 years 4 months ago #61418
Yay those pearls keep popping up here there and everywhere
Replied by alanrt54 on topic Re: Warning Light
Posted 12 years 4 months ago #61425
If you've got an Android phone you could buy a bluetooth Elm 327 adapter and download an application called Torque instead search for elm327 on the T Bar for an earlier thread by me.
Time to create page: 0.575 seconds
