Warning Light
the amber light on my dash stays on when im driving.
What does this mean? and is it serious.
Its just come back from a MOT and hasnt been on before ..
- John and Sue
I got a cheap OBD2 one from ebay and cleared my fault with my phone.
Check these out:
http://www.the-t-bar.com/en/forum/9-mgf-tf-pitstop/52267-how-to-use-a-bluetooth-odb2-reader#52267
http://www.the-t-bar.com/en/forum/21-david-aiketgates-guides/3819-OBD2
A garage will charge you £40 for this to be done.
I'd recommend getting one
- John and Sue
- Leigh Ping
Ebay OBD2 Readers link.
They come with a booklet with a comprehensive list of codes.
It plugs into this port here within the fusebox compartment under the steering wheel.
Where abouts are you?
I will happly plug my scanner in for you and read the code.
However it may disappear anyway. Sometimes if the ECU doesn't detect a fault over a number of ignition events it will clear the light, this happened yesterday on my wifes ZR after some brake work.
On our F the EPAS light come on after the emissions test on the MOT but clears once you drive properly.
- Leigh Ping
talkingcars wrote: On our F the EPAS light come on after the emissions test on the MOT but clears once you drive properly.
Ooh.. a pearl of wisdom right there. :broon:
