Free Bits
Do you have one of the white clips that hold the bonnet stay down?
David Aiketgate wrote: Do you have one of those spiral rubber stops that fit in the door?
Yes to the rubber but no to the bonnet stay clip. Pm your address and I will pop it in the post.
- a Guest
- Visitor
- a Guest
- Visitor
bazessex wrote: Centre console yes. Air vents yes. Cowl a maybe since not sure if it has all the fixing tabs. Will look tomorrow.
You are a star, let me know what the postage will be and I will paypal it to you :broon:
bongodave wrote: Decent tan hood, 52mm throttle body? I will pay for these as bit much.
I have some decent hood frames but hoods are all black and had it. 52mm throttle bodies I only have 1 left and I will fit it eventually.
Mal7921 wrote: Fuel pipes, fo you have the fuel pipe assembly?
Which ones? From tank or engine end, or all of them? Yes I do just let me know which ones.
It's from the tank, the ones that run along the side
I probably don't need all the pipes, but the whole assembly is probably easier to remove than individual bits.
