Free Bits
- a Guest
- Visitor
Don't worry about the fixing bits on the dome thing, I can use mine, yours will be to get me through while mine is away
![;) ;)](/media/kunena/emoticons/11.png)
Yes I have an interior project in mind :whistle:
- a Guest
- Visitor
Psymon wrote: Now i'm intrigued Ben
Don't worry psymon yours is ready for subframes off then done. :broon:
My TF has been rear ended at some point I might toy with the idea of reshelling the TF bits into another car, or might not bother, see this post:
http://www.the-t-bar.com/en/forum/9-mgf-tf-pitstop/63132-strange-things-i-found-under-my-bumper :help:
Did you mesh the rear bumper? would save a job cutting to size
![:) :)](/media/kunena/emoticons/8.png)
- Looney toons
- Journeyman MGer
Craig, it is often the case that the window needs adjustment, or the roof itself.:yesnod: rather than the rubber seals themselves.Looney toons wrote: hi i dont suppose you have the rubber for up and over the screen and down the pillar mines not sealing propperly on the drivers side think it needs replacing , but i am new to all this :drive: all help wecome cheers craig
Have a look in the 'How tos'.:broon:
- a Guest
- Visitor
David's correct, it's an easy job to remove them, give them a good clean up with hot water and re fit ..
If yours are showing no sign of wear, rips, rubber perishing then its more than likely a window adjustment, or a cloth stuck in when washing your car
:welcome2: the forum, do an introduction thread so we know who you are and a bit about you, plus photos of your car are a must :broon:
And the little rubber plugs for the wing mirror screw holes - I bought some from eBay and they are too small :lol:
Thanks.
- mandymay1971
