water ingress
  • groovylee
  • 1997 MGF 1.8i in COF
water ingress was created by groovylee
Posted 12 years 3 months ago #78252
hi all,
well, i had a busy day today. found that my boot and passenger footwell were wet through, so set to with finding out the reasons. so, first up, remove all of the interior :omg:
found some nice rusty bits :( thankfully they passed the 'big screwdriver stabby poky' test :broon: so no real damage.
found the source of the passenger footwell leak......
so set about changing the airbox for the later type:
it was a real pain in the arris, with the most difficult bolt having rusted solid, so i had to hack most of the box out to get to the bolt :rant:
and then did some cleaning while i was there.... :whistle:
so, tomorrow is reassembly time, hopefully the interior would have dried out in the old mans garage.
and i need to figure out the water ingress into the boot. are there any common causes? i was thinking boot seal, but can't see any signs of water entry around the seal. it does seem to be mostly around the passenger side of the boot though if that means anything to anyone?
cheers all, will post up pics of the 'changes' tomorrow......... ;)
Lee
Last Edit:11 years 10 months ago by groovylee
Last edit: 11 years 10 months ago by groovylee. Reason: fix picture links
Replied by paulsmgf on topic Re: water ingress
Posted 12 years 3 months ago #78253
Nice work lee
i found the seals on the rear lamp clusters to be at fault
The following user(s) said Thank You: groovylee
  • groovylee
Replied by groovylee on topic Re: water ingress
Posted 12 years 3 months ago #78254
cool, cheers paul, i'll take a look there then :broon:
  • Visitor
  • Visitor
Replied by a Guest on topic Re: water ingress
Posted 12 years 3 months ago #78258
Good job :broon:
Replied by bensewell on topic Re: water ingress
Posted 12 years 3 months ago #78272
Feels good taking it to pieces n getting it back together again :-)
  • groovylee
Posted 12 years 2 months ago #78493
ok, so i worked on the car from 0900 to 1930 today :nonod: but i got a lot done :yesnod:
first off, a big :broon: to paul for correctly guessing the source of the water ingress into the boot - it was indeed the rear light seal. all sorted now, thanks mate :beer:
so, on to tidying up the bonnet area - some silver spray should do the trick :)
i also sprayed the centre console red, the vents red, and the door card cappings red....... only got pics of the centre console though due to time :(
the clock and oil temp gauge have been swapped round, and backlit in red LED. will do a proper interior pic thread nwxt week when i'm off work again :broon:
cheers everyone,
Lee
Last edit: 11 years 10 months ago by groovylee. Reason: fixing pictures
Posted 12 years 2 months ago #78494
Well done mate and thanks for sharing when the twins are a bit older I'm going to havea few mg days like yours you have got loads done and the silver spray looks brilliant.
Hats off to you and a welcome to the world of we can do anything club :)
Replied by bandit on topic Re: water ingress
Posted 12 years 2 months ago #78502
did you replace the seal/seals ? also youve worked hard and done a good job,pour a drink :beer:
by bandit
  • groovylee
Posted 12 years 2 months ago #78507
thanks bandit. no, i used the dreaded silicone :nonod: when i find some new seals that aren't £18 each i'll replace them ;)
Posted 12 years 2 months ago #78511
Don't worry silicone noise nails and gap filler is holding my entire house up barrats thebuilder swear buy it
  • Jimuth
  • "So, how much is that going to cost?"
Replied by Jimuth on topic water ingress
Posted 11 years 10 months ago #106196
Lee (and Paul if you're reading - I know you mentioned it when you came round)
Any tips on the silicone work in the lights?
It's one of the jobs for the weekend - is it a case of sealing\reinforcing the light gasket or more a case of "plug that hole"?
I know you mentioned about ppl putting some plastic in there Paul but I can't find it anywhere on t'interweb :-?
Ebay + Nectar = lots of MGF points
by Jimuth
Time to create page: 0.468 seconds
