Door card
The silver panel on the mk2 F door card. Do I need to remove the door card to get this off or can it just be pulled from the inside.
Don't want to just pull it if it's gonna break. I'm assuming it is removable
![:-? :-?](/confuse.gif)
by Fred
You need to pop the whole card off to get to the clips.
by talkingcars
The following user(s) said Thank You: Fred
- highflyer1000
- Journeyman MGer
at the back you will find some none removable clips .....paaahhhh.......lever 1 or 2 of the little tabs out of the way on each clip , it then slides off the pin easy .........for reattachment bend them back and place them on the pin and use a socket to push them back down
Paul D
Paul D
Last Edit:11 years 4 months ago
by highflyer1000
Last edit: 11 years 4 months ago by highflyer1000.
Time to create page: 0.464 seconds
