Modding
tim-mgf wrote: Don't forget the splitter !
Have you fitted it yet?
No it hasnt stopped raining and I need some Ramps
I have fitted both LoLarm II coolant alarm and remote boot solenoid, it should have taken a couple of hours but has ended up being done over 3 days due to the weather.
I used the same point for the live for both, its live when key turned to I and II, so as long as I don't push the boot switch while driving
![:( :(](/media/kunena/emoticons/5.png)
Found a nice place for the relay just under the fuse cover
Wiring behind the drives side panel
Switch mounted, its from a SAAB (I liked the look) although cant really be seen
Wiring tidied on inside of fuse board cover
Wiring tidied for boot solenoid
The boot release cable, where the solenoid needs to pull upon. Point to note here is that although I wired as per instructions the solenoid pushed instead of pulling ! Wasn’t happy, easy to rectify though.
So this is my first attempt, all connected up using the bits supplied, it didn’t work just kinked the cable !
Good point to add here was that seeing as the Mrs had gone out I couldn’t test the solenoid as the switch was in the dash and I needed to be in the boot area !!! So I had to rig an extension of the switch
So needed to find a better way to activate the boot mechanism, so here my scarp yard challenge skills came into play. I made a cable pull that would actually fit on the mechanism and not the cable using some spare cable and a connector
Here is my improvised cable attached to the boot release mechanism, and it works great, also means no fouling of the mechanism should the solenoid fail/jamm.
Solenoid in position, again point to note here, the rather weak piece of metal bracket supplied does bend a bit when solenoid energised so I will be replacing this when I can get a stiffer bit.
I ran both cables for the LoLarm unit and the boot release together for ease
Nice and tidy
quote="Tibs" post=108480]The coolant alarm was dead easy to fit the instructions were self explanatory, I will add some more pictures tomorrow[/quote]
Glad you got the alarm sorted very easy to fit, boot release looks a bit more dificult.
paul
talkingcars wrote: Nice bit of improvision but be mindfull that crimp terminals will eventully fail.
Yes I thought they might but worse case is I would have to use my key, and then just replace the cable, seemed better than something that might cause a jam and then boot wouldn't open at all
I'm sure it will make its way into the big list! :broon:
bensewell wrote: A tie wrap might do it
Lol, that would have worked, why didn't I think of that
![:-? :-?](/confuse.gif)
Mind you might have been a bit bulky considering the lack of space
Solenoid fitment, I wouldn't use the supplied bracket its too weak and bends each time used, I will be replacing it very soon.
Boot switch placement
Coolant alarm switch placement
