New front hubs.
Well, I cleaned up the hubs today.
Although it looks worse, it is only surface rust that they have acquired while in storage.
I got the drill and Dremel out with wire brushes on and gave them a good seeing too.
Here you can see before on the right and after on the left.
I then degreased them and sprayed them up with this stuff, using my airbrush.
http://www.rust.co.uk/products/category/28117/epoxy-mastic-rust-proofing-chassis-paint/
I think they look a lot better now.
I also gave the new TREs a coat to help them look new for longer.
as ever,
Rob
by Bertl
- Diesel Destroyer
I'm lucky. When guru Pitka did my front brakes he stripped the front hubs and got them blasted.. Zinc primed then new bearings fitted and I top coated them in 2k..
Takes forever prepping stuff.. But so satisfying to see it all nice n shiny.
:broon:
:broon:
I didn't think about painting my new TREs before fitting them yesterday and I've had the tracking done now. Am kicking myself as that is a sound idea. They look good too.
It's on the list for another time.
by Beth557
- Tourbillon
Wire brush and black Hammerite will take about 10 mins! even on the car
by Tourbillon
Hammerite is rubbish. You will be back to it the next year.
- Tourbillon
Well there's a view I have found it quite good and not had any real issues.
TB
TB
by Tourbillon
I always used to use it because it is handy and you can get it in rattle cans, but I have never had great success on relying on it to keep rust at bay. It is a good easy solution if you accept that you may need to redo it each year, but as a long term coating it isn't very good. That might have something to do with me living next to the coast. :yesnod:
