Fitting a TF OE rear brace TO MGF.
- GT MG SPARES LTD
Fitting a TF OE rear brace TO MGF. was created by GT MG SPARES LTD
Posted 10 years 11 months ago #138164The rear inspection cover you will need to drill two holes through for the braces to bolt up to.A TF inspection cover the holes will obviously be there.
On the TF there are tapped holes for the brace joining bracket to bolt to on body which are not there on the mgf.Simply drill through the rear boot rear of engine panel and put two nice stainless bolts through and bolt up with washers.
Replied by David Aiketgate on topic Fitting a TF OE rear brace TO MGF.
Posted 10 years 11 months ago #138192David
- GT MG SPARES LTD
Replied by GT MG SPARES LTD on topic Fitting a TF OE rear brace TO MGF.
Posted 10 years 11 months ago #138196If staying to the idea of keeping it simple and cheap the front subframe braces off a tf and behind heater control brace also helps stiffen the body roll up.
Replied by cairnsys on topic Fitting a TF OE rear brace TO MGF.
Posted 10 years 11 months ago #138198Robin
Robin
- Leigh Ping
- Online
Replied by Leigh Ping on topic Fitting a TF OE rear brace TO MGF.
Posted 10 years 11 months ago #138200Please Log in or Create an account to join the conversation.
- Diesel Destroyer
Replied by Diesel Destroyer on topic Fitting a TF OE rear brace TO MGF.
Posted 10 years 11 months ago #138201The under dash brace will need some mounts welding in (possible without taking dash out) and the front subframe cross brace too (but you'll need solid subframe mounts)
I've gone one step further.. With additional custom bracing for bonnet, boot, door openings (currently in progress) suspension top mount cross bracing and top mount strengthening..
VHS sell the 3 braces as a kit.. But they do come up second hand on E bay now n then
Don't forget the TF had revisions to the screen surround though to increase shell torsional stiffness.. As well as the 3 braces
- Rich in Vancouver
Replied by Rich in Vancouver on topic Fitting a TF OE rear brace TO MGF.
Posted 10 years 11 months ago #138204Please Log in or Create an account to join the conversation.
Diesel Destroyer wrote: Don't forget the TF had revisions to the screen surround though to increase shell torsional stiffness.. As well as the 3 braces
Been thinking about that and I s'pose you could inject the hollow sections of the windscreen frame with an expanding foam, which would add a little stiffness.
- Diesel Destroyer
Posted 10 years 11 months ago #138207Diesel Destroyer.. 'The bringer of dreams'
- Diesel Destroyer
Posted 10 years 11 months ago #138209Rich in Vancouver wrote: I would be inclined to put some welds on the boot wall mounting bracket, or at least make up a full size backing plate to clamp the bracket to through the boot wall. I don't think that washers alone would give enough rigidity to the sheet metal.
I went for 6mm plate one side.. 6mm angle the other.. Boot braces added to stiffen rear fire wall.. Engine bay seam welded.. Top shock mounts seam welded and gussets and cross braces added..
Ta over kill :bust:
- GT MG SPARES LTD
Posted 10 years 11 months ago #138212Rich in Vancouver wrote: I would be inclined to put some welds on the boot wall mounting bracket, or at least make up a full size backing plate to clamp the bracket to through the boot wall. I don't think that washers alone would give enough rigidity to the sheet metal.
A backing plate is ideal but the bolts go through the double skin as where the the tf only bolts into one skin.
- GT MG SPARES LTD
Ta over kill :bust:
Yes as explained in original post,keeping it simple and cheap.
Anybody serious about tracking go to a MGOC championship meet and have a peak outside the pits.15 inch small wheels with A048 TYRES,leda adjustable suspension polybushed a good start.Fully seam welded,Fibre glass bonnet boot hardtop with roll strengthening cage quick rack Oh dont forget a in date fire extinguisher.And a MSA race licence.
A CUP CAR is ideal but a bit pricey £7500 TO £9000 when they turn up a lot of them went to Australia.The cup cars was £30000 new from mg rover sport,i think they only built 30 a VHPD 190 engine with dry sump, straight cut gearbox with LSD.
