Wings are off.
Wings are off. was created by cjj
Posted 10 years 9 months ago #141343
I've taken the front wings off to check for corrosion, tart up and get the car ready for when I get my newly sprayed wings back.
[IMG
[IMG
There wasn't as much corrosion as I thought there would be, so I am just wire brushing the few rust spots and spraying underseal around to give a good cover.
[IMG
[IMG
Unfortunately, one of the studs that hold the front bracket in place sheared off, so I will have to drill that out and use a rivnut or similar.
[IMG
Replied by cairnsys on topic Wings are off.
Posted 10 years 9 months ago #141346
Is there a How To anywhere that describes front wing removal and perhaps more importantly, refitting?
Robin
Replied by cjj on topic Wings are off.
Posted 10 years 9 months ago #141347
There will be. :broon:
I took plenty of pics. ;)
Replied by Leigh Ping on topic Wings are off.
Posted 10 years 9 months ago #141348
cairnsys wrote: Is there a How To anywhere that describes front wing removal and perhaps more importantly, refitting?
Robin
I don't think there is.. :hugs:
Posted 10 years 9 months ago #141349
cjj wrote: There will be. :broon:
That was me being subtle :whistle: but
THANKS :broon: :broon:
Posted 10 years 9 months ago #141357
I would never have guessed. ;)
The following user(s) said Thank You: Uncletone
Replied by Uncletone on topic Wings are off.
Posted 10 years 9 months ago #141377
I'll look forward to that "How To" as it will be the next job at the end of the summer for me to do the front wings on the F
Thanks Clive
Tone
Replied by bensewell on topic Wings are off.
Posted 10 years 9 months ago #141384
From what I can remember there were two bolts at the bottom, two / three in the wheel arch and one on a metal strap thing near the indicator.
Posted 10 years 9 months ago #141406
Been busy today.
Repaired the sheared stud. It now has a stainless nutsert and stud.
[IMG
[IMG
I then removed all the old flaky chip resistant paint with a drill and a wire wheel. Cleaned up some of the rust spots too.
[IMG
[IMG
And then sprayed with waxoil.
[IMG
[IMG
Posted 10 years 9 months ago #141423
Robin
Here you go http://www.the-t-bar.com/forum/22-cjj-s-guides/91234-how-to-remove-the-front-wings#141422
I will add to it if I need to when I refit the wings.
Replied by Davem on topic Wings are off.
Posted 10 years 9 months ago #141424
CJJ thanks for your how to's they are much appreciated. I have been using your subframe and gearbox removal guides.
[IMG]ht[/img]
by Davem
Posted 10 years 9 months ago #141426
Just remember that you've got to put them back in again. ;)
Time to create page: 0.541 seconds
