Wings are off.
There wasn't as much corrosion as I thought there would be, so I am just wire brushing the few rust spots and spraying underseal around to give a good cover.
Unfortunately, one of the studs that hold the front bracket in place sheared off, so I will have to drill that out and use a rivnut or similar.
Robin
Robin
I took plenty of pics.
- Leigh Ping
cairnsys wrote: Is there a How To anywhere that describes front wing removal and perhaps more importantly, refitting?
Robin
I don't think there is.. :hugs:
cjj wrote: There will be. :broon:
That was me being subtle :whistle: but
THANKS :broon: :broon:
Robin
Thanks Clive
Tone
Repaired the sheared stud. It now has a stainless nutsert and stud.
I then removed all the old flaky chip resistant paint with a drill and a wire wheel. Cleaned up some of the rust spots too.
And then sprayed with waxoil.
Robin
Here you go http://www.the-t-bar.com/forum/22-cjj-s-guides/91234-how-to-remove-the-front-wings#141422
I will add to it if I need to when I refit the wings.
